I replaced my Rad Support due to rust issues in the left side and decided to do all the “while i’m in there” repairs including radiator, condenser, etc.
Anyways, when removing the radiator hoses, I collected as much coolant as I could into a container UNTIL i pulled the damn transmission hoses and the ATF spilled on to the container I was collecting the coolant on.
SO, now I have these questions:
- When I put the transmission cooler and hoses back, how should I go about the refill? How will I know how much ATF is enough?
- Now that my collected coolant container is contaminated with ATF. Should I do a radiator flush? Or just fill the coolant that is missing only? If flush is the right thing to do, any links that describe the process?
TIA
TIA
