I ran an aluminum rad on my 350 conversion, and it did not cool as needed. In fact, I would boil over at times
I finally switched back to the original brass one after I had it cored and cleaned, and installed a hotter, 190 degree thermostat (Was running a 160).
I'm running a cheapo summit eletric fan, and Ill NEVER go back to an aluminum one, period. I now max at 220 degrees while crawling, and 220 is my no means hot for a 350
I went back to brass after an old school radiator guy explained some things to me:
1. Brass will always cool better than aluminum, comparing both types with the same number of rows and size. Lost over the years is that people wanted LIGHT radiators, so most went with aluminum. Brass cools better, period. Yes, brass rads are heavy
2. Most folks when they try to run 30-40 yo brass radiators don't get the cooling effect desired because they are clogged and dirty from corrosion over the years. 50 bucks will get it rodded out and like new again
3. Thermostats: A radiator cools by the coolant spending enough time in the radiator body itself for air to flow thru the radiator rows to bleed of the heat from the coolant before it flows back into the engine. A low temp (160 or so, or no thermostat), opens too soon, and allows the coolant to run back into the engine block before it has had time to bleed of the appropriate amount of heat. So you are better off with a 190 stat or so, than a 160 thermostat
My electric fan is manual, that is, I turn it on if it gets about 210. That typically only happens if I am crawling. If I had a temp actuated fan, I wouldn't even have to worry about it
So combine 2 and 3 above, and you wont get the desired cooling effect
I know, #3 above almost defies logic on the surface. But believe me, I went thru it all. Cleaning out the stock radiator along with going with a hotter thermostat (190) did the job for me
Im not even running a fan shroud.
Sorry to steal the thread if you arent having cooling probs
