Slomo
It's Complicated
My radiator is leaking from a 4" long crack in the top plastic tank so it is getting replaced with an all metal one along with the thermostat and gasket. All hoses are pretty new so will stay. I need to replace my high pressure PS hose which is leaking badly and thinking I will rebuild the pump while I am in there since it moans a lot. My front crank seal is leaking for sure but I'm not positive if the oil pan arch seal is or not. I thoroughly degreased the engine then checked for the source and found the front main wet and wet around the wire and small cover plate on the front underside of the oil pan and am thinking it may be from the oil pump area as well as main seal. What seals and gaskets do you all recommend that should be done but won't break the bank too badly? I need to assemble the must have parts ASAP as this is my daily driver.
Radiator pic for fun:
