pbgbottle
Forum Lifer
i usually just drive mine there while in line up pop the hood crank up the idle , do the test drive out turn the idle down and away i go . does sound like the engine is gonna blow when it is reving up around a 950- 1000 rpm also how hot is your engine .if it is running hot it will fail on the hc's also .i usually run mine straight there just make sure the choke is fully off . the only reason they say to bring the vehicle warm is to make sure the choke is off , i also have a buddy with a 454 in a 67 camero . aluminum rad electric fan and mechanical fan . he goes as far as driving straight there .turn off engine . wait his turn .actually pushes the car in the lineup and into the testing facility .starts it up runs the test . and passes , he has a heat issue . if his car sits in that line up for more than 5-10 mins his engine is to hot and fails on the hc's !!! heat will also cause problems ?? just a thought
