My 83 FJ40 with smittybuilt. tight but no issues. Again for $100 the smitty is a decent option. I was pleased with quality of the Tuffy though for $275. Not pleased with the fitment hassles.
just curious - has your shift lever been modified or replace? I have seen some that are at more severe angles than the original and can cause issue.
I installed in my 74 with their bracket no problem and it does NOT interfer with shifting. They have been doing this so long and make those brackets so specific, it tells me something on your end changed?
I guess brilliant minds think alike... I also have the Aussie floor mats in mins and they look good, too.
I may take your advice and change the bend in the shifter shaft. How do you remove the shifter? I think I heard that there is just some sort of nut holding it in once you remove the boot, but I've never looked under there to see what it looks like. Do you have to remove the "inner boot" from the transmission to do it? If so, how does that come off?
I wasn't looking forward to trying to modify the console mounting system to make it work like it is. I'm afraid it would be too far back to use as an armrest if I did, too.
I hadn't thought about putting a filter in the bottom of the stereo compartment before, but that sounds like a good idea.
Thanks for your help!
