Will Van
GOLD Star
I'm thinking about swapping an H55F 5-speed and 60 series twin-stick split case (from Georg at Valley Hybrids) into my 1977 FJ40.
As most of you know, the 40 series 5-speed top plate covers for the H55 are unobtanium. I realize some members are working on creating a reproduction, but for now, I need to run the 60 series top plate which moves the shift lever rearward.
Also, the '77 trucks have a one-piece transmission hump, without the later-model inspection cover.
My plan is to swap to a two-piece cover available on the '79 and later truck, and use a raised City Racer inspection cover, and then just cut the holes for the 5 speed and t-case levers to fit.
Will this work? Are the trans covers interchangeable between 1977 and 1979? Is there an easier way to do this? Just cut my current trans cover?
Do I also need to modify the fuel tank and transmission hump where the split-case will sit?
