When I bought my Japanese ’91 PZJ70, I knew the tie rods would need to be changed because the boots were shot. While under it, I found that the birf seals also needed replaced. I wanted to post on here to show my process for refurbishing some of the old parts, share what parts I found and used, and lastly ask a few questions that came up during the job. Those questions are as follows:
1: I think I know the answer, but any chance this axel is still serviceable? Maybe if I press the seal in a little farther than flush? Is there a reliable source? This is the shorter axle, thankfully the long one is in great shape.
2: The brake rotors are different in that the wheel studs go THROUGH the rotor and are pressed into the hub, meaning swapping the rotors you have to also swap or replace the wheel studs. The bolts that actually directly hold the rotor and hub together only have two bolts; the 70 series images I found show a set of 6 all the way around.
3: What is this grove on the right side of the 8-bolt flange of the knuckle? It looks machined, is not threaded, and is on both sides. It was sealed with some sort of non-hardening sealer, doesn’t seem like the proper way to seal it up. What should plug this?
4: Not a fan of having the brake line connected to the brake dust cover. The caliper and dust shield being tied together just makes things difficult. This doesn’t appear to be a 70 series thing, is it another instance of 80 series stuff? Anyone else bothered by this enough to change it up?
5: In the knuckle I found a bit of black viscous grease as expected, but also found some really thick orange waxy stuff. Is this just really old grease from before moly was commonplace?
6: Given all these observations, any idea what my axle set up is and if it is stock? From what I’ve found here and elsewhere online, the parts I have are not consistent with other 70 series. The seal kit I purchased was too small, and after talking with Marlin Crawler reps it sounds like I need the 80 series seal kit (the wheel bearing kit does fit however). What gives? Also, are there torque specs summarized somewhere on here?
Thanks for the help. I'll upload some of the refinish work I did to make things pretty and try to keep rust at bay in a bit.
