Without a tank, there is no need for the switch. Just hose everything so it is free flowing, bleeds excess air when not connected to the tire.
Excuse my ignorance, what's the best way to do that?
How many of you are running tools on this? My VIAIR medium duty with tank is pretty slow at re-filling the tank. At best, I can get 5 lugs off before needing to wait a few minutes for pressure to get back above 100.
I apologize for bringing up a super old never ending thread but i had a couple questions regarding wiring up my Puma over the rear wheel well
With this be my first attempt at any sort of wiring I wanted too see if I was on the right track, I could obviously pay someone to do this for me but part of owning this rig is have fun and learn form it. So any advice would be greatly appreciated
I thinking about running these cables
http://www.amazon.com/dp/B000OV7I6E/?tag=ihco-20
with these reducers/Splicers to line up the factory Puma wiring and the warn cable
http://www.homedepot.com/p/Blackbur...cer-10-Piece-per-Case-ASR1114-B2-10/202209263
and some heat string tubing for insulation
http://www.waytekwire.com/products/1381/Tubing/
Then just follow the existing factory taillight wiring and connect to the battery
I wanted to keep the quick disconnect inside the rear quarter panel just to keep any spying eyes thinking it's more hard wired that it is, I know if someone wants to steal it they will but keeping the quick disconnect hidden might make it just a little bit more difficult.
The only thing I think i'm missing would be a fuse, I'd like to try and inline one if that makes sense or possibly adding an auxiliary fuse box that i can add too later
Thanks for you help
Jeff
. If you have no means to making your own it could be consider a value. If you do have resources available consider looking at jumper cables for a wire source.Thanks Phil.
I looked into making a couple quick disconnects with jumper cable tails but might be a bit over my head with the soldering and crimping.
Blue thanks for breaking that down.
After reading the thread a bit closer and your post 110 I spent some time on powerwerx and finding some disconnects and gonna go for it.
We're you able to eliminate the reducer/splice by using the smaller SB50 with the wires coming directly from the compressor?
I appreciate all the help.
If a breaker fails you'll also be SOL if you don't have a spare.
