Here's a couple of photos of my installation. So far , so good
Photos didn't upload, bummer!
Why do you have a male air line fittings on the compressor instead of the standard female fitting?Well, here's how I did this. I'm running both ARB air lockers and an OBA fitting. Both solenoids and the air chuck, will be regulated the same.
Anybody see something amiss with this setup. The only thing I see, is maybe a bracket to hold the nipple going to the two ARB solenoids?
Thanks,
Ron
Good question! No real reason, just grabbed a fitting out of my stash, as I haven't made up an air line yet.
Really just wanted to see how everything is going work together. I'm more concerned about the solenoid placement.
Nice install, and welcome!
You may have run out of space for photos, you will get a lot more after you get to 10 posts and should be able to upload them then.
FishEH,
How did you plumb the solenoids, for the lockers? Do you use the same regulator for all?
Thanks,
Ron
Yes I use the same regulator for lockers and tools. Lockers run at about 75psi. It's pretty easy to adjust the regulator when I'm back there if I want more for tools.
3/8" bpst
Question for you guys. If I'm only using my PUMA to air up tires, is there any major disadvantage to ditching the tank and using just the compressor?
And if I did that, what kind of pressure switch would I use? My switch right now has a line to the tank, which tells it that it's reached it's maximum PSI and to shut off.
thx
Andrew
