OK... I'm putting a mini-truck power steering set up with a saginaw steering pump in my 74 40 with a SBC 400 motor. We ran into an issue when trying to mount the pump to the block. There is no room (pump hits the engine mounts)! I need to mount the saginaw pump high. Apparently, these brackets are not easy to find as I have searched high and low and called every junk yard within 50 miles. However, I did find this bracket set and was wondering if anyone knows if it mounts high (to the head) or low (to the block):
Muscle Car Metal
I'm thinking this might be it based on Dingadong's post here:
https://forum.ih8mud.com/40-55-series-tech/470936-power-steering-conversion-74-fj40.html
My head is tapped with 3 holes, so do I assume correctly that the bracket I posted will work and get the pump up higher? Any help is appreciated!
Thanks.
Muscle Car Metal
Thanks.
