Builds Project X² (2 Viewers)
Ok,I'll let secret out.
He's getting 21s with spiners so the laser pointer on the valve stem can shoot off in different directions.
Sent from my DroidCruiser
i know gary...he'd never be that gay, and he knows me well enough to know that i'd slap him upside the head with a 2x4
Now this is getting funny!!! :popcorn::beer:
All thats left in the engine compartment is finishing the AC lines, adding the air inlet tube with the MAS, Power steering lines, new batteries, and a fan. Also did the hood lift mod using some old 80 series rear hatch shocks I had.
wow!:eek:
that looks soooo professional.
excellent work.
are you going to do anything where the 60 wiring harness enters the fender skirt areas right next to the fire wall?
like a rubber banded p-clip or something just to hold the harness off the sharp edge of the inner fender wall? or do you think that the simple fact that its in a plastic wire cover dealy is enough to stop if from rubbing through after a while??
wow!:eek:
excellent work.
There will be a protective sleeve and it will be fastened to the inner fender.
Where are the pics?
I'm pretty sure I saw project X driving around moab this afternoon.
Gary, amazing build!! Quick question looking for info on the 62 tank tray??? I need more range in my S/C'd 80
Where are the pics?
except this is project x2...pics of project x would belong in the project x build thread ;)
if it is project x2 up and running, i'm sorry i'll miss seeing it gary. have a great time in moab.
very cool build Gary.
wngrog said:
Hmmm......I can't believe you did not tell me about this build.
Better late to a party than never. Great job on this.
Where they hell have you been? I think you are last one to know.
Arya Ebrahimi said:
Or is the reason we're not getting any updates because he's in Moab with Project X?
This...
gary magic build very detailed , starting the same conversion here in sunny south africa but with the 3uz not the 2uz , 2uz are still a bit pricey.
the 80 that we used as a donor is the uk spec vx . so im busy with wiring and such as i want to transfer the abs and factory difflock system over as well , i think ive got my work cut out for me , but all in the fun off doing it , just one question gary what did you do about the rear of the body that fouled in the arches did you tub it to fit lower on the frame , thinking of lifting and doing a slee type rockslider to try cover up some of the frame rail , also the chassis we cut in a zig zag pattern and removed the outer rail and once together fitted it back albeit 5 inches shorter as a gusset almost that fitted across the joint.
