Build Project Cherry Bomb
All of my previous rigs (except my 80-Series) had automatic lockers in the front, but most of them were LocRites. I've never had an issue with them, but I really don't know any different. This Detroit is definitely more positive, though!
Last night my buddy came over and helped me install the AAL. It all went together relatively smoothly. The only main issue we came across was Skyjacker designed the AAL around a stock leaf pack. Since TG’s leafs are 56”s long, the center pin hole needed to be moved about 2” over. I just drilled a new hole and called it good.
Before:
After:
It is definitely stiffer in the rear, but that makes it drive a lot better on the street. I also had my buddy and my neighbor climb up on the back bumper to see how it would handle being loaded down. That was a little over 500 lbs on the bumper and it only squatted about an inch. That should be perfect for my needs.
Another note, I am very impressed with Skyjacker. When you turn the instructions over, this is what you see:
As a Christian, it is refreshing to see a large company that isn’t afraid to proclaim it’s beliefs. It may make them unpopular and against what most would consider good business practice, but it made me proud that they have the balls to minister to people by meeting them where they are.
Last but not least, I drove it to work today just to get everything settled in. I want to put some miles on him and re-torque everything before wheeling it again at the end of the month. This is in my level parking garage at work. Man he looks good!
that's so refreshing when you can drive your " trail " ride to your office and back .. ( it is to me ) as you do in your DD ..
Kudos to you also for being willing to put your faith out in the open like this.
Don
2M radio? Nobody answers on that when you call... :doh:
:p The little radio available to call back just wasn't strong enough to respond although I did try. Besides I was helping an 80 get off the trail.
Well I guess it is time for an update... A local 4x4 club was hosting their annual poker run last Saturday, so I figured that would be a good chance to see how the spring modifications worked. I must say that even with just my trail gear in the back, the suspension worked very well! The 4Runner has enough weight to still work the suspension. It's not super flexy, but the Detroits make that less of an issue. All in all, the 10% loss in capability on the trail was over-shadowed by the 90% increase in functionality.
Now on to the bad side of things... Ever since I bought the Runner, the PS would whine in 4wd. I knew that hydro-assist would be in the future plans because she was a workout to wheel. Well the PS pump decided to fail at a horrible time while navigating a trick section of trail. I was using a bit of momentum because of the mud and ended up laying the Runner on it's side. It happened pretty slowly and the slider took the brunt of the flop, so that was a blessing... And my girlfriend wasn't scared off by her first flop experience! LOL! Another participant was able to rock the truck back onto it's tires and help get me up and out of the trial.
I was very luck that the damage wasn't that bad. This is all of the sheet metal damage...
After that, we stuck to gravel roads to finish the Poker Run. 36x13.50 bias Iroks with 8 psi of air is very difficult to control with no power steering pump! I have decided to upgrade to Trail Gear's Rock Assault 1600 PSI pump kit. For now that is all I'm going to do, but that will give me the flow and pressure to run a ram in the future. I may have to do a work party soon to get that installed for snow wheeling. All in all, I am glad it wasn't worse and I am reminded how awesome people are on the trail. A big thanks to all that help!
With the Christmas Tree Run coming up this weekend, I was pushing hard to get my power steering fixed this week. I ordered Trail Gear's 1650 psi pump kit thinking that it would be a great upgrade for the time being until I can put a ram on for hydro assist. Reading the instructions showed that the cooler that comes with the kit wouldn't work with an A/C truck because of the A/C condenser fan is where the cooler is supposed to mount. I ended up pulling the bumper and grill off to take a look and see what I could do instead. It may be a wheeler, but I really like having A/C!
The truck has a A/T cooler in the radiator that isn't being used and my original thought was to use that as my PS cooler. After some Google-fu, I decided that wouldn't be a good solution because the coolant would raise the PS fluid temps. My compromise was to buy a single pass cooler to mount below the passenger side headlight. The next night my buddy Mike, TonsOFun, Mr. Jitz and his son came over to help knock this out. The hope was to get it finished in one night starting at 8:30 pm... On a weeknight. (I have awesome friends!) In typical Trail Gear fashion, the instructions sucked. It also is more of a "one size kinda fits nothing" ordeal. It seemed like every step took some ingenuity to figure out. I am so glad that I wasn't tackling this on my own! When we got to the part of mounting the cooler, my friends did what they should and laughed at me. The fact of the matter was the mini cooler I bought wasn't going to do a thing. I finally came to the realization that steering is more important than A/C and the fan needed to go. The next road block was the cooler was sized to not have the A/C condenser at all, not just the fan. A little frustrated, we figured out that the mounting holes on the cooler were the same width as the mounting location of the fan. That would put the cooler lower and out more than it should be, but I could trim the grill where nobody would see and it should work. We got everything together and started bleeding the system with the engine off. It just wouldn't bleed! I swear it seemed like the fluid was multiplying by itself in the system. Power steering fluid was everywhere... After about 50 or 60 turns lock to lock, we decided to start the truck to force the fluid through system. That is when we found a loose banjo fitting on the ABS actuator when it started spraying fluid. ("Oh! That's why it wouldn't bleed...") We worked it until the bubbles were mostly gone out and called it a night. It was about 3:30 in the morning.
The next day I was back at it after work trying to button everything up. I took the cap off the reservoir and PS fluid came pouring out! Like I said before, it's like the fluid was multiplying... Now I'm super confused and slightly worried. I sucked out some fluid and went back through the bleeding process. Once again I had very small bubbles, but I wasn't seeing any leaking. I can't be sure of this because it is hard to look for leaks when everything is wet with fluid and I needed to turn the wheel. I went until I didn't see bubbles anymore and started putting everything back together. I trimmed the grill and re-did the connection for my aux lights with a new plug. I got the bumper up to bolt it down and my winch ran smack dab into that PS cooler. I was not happy... So, everything came back off. I didn't want to remove any hoses, so my options were limited. I ended up finding the one spot I could get the cooler, but the only way to secure it was with zip-ties. I figured if it was good enough for Volkswagen...
URL]
Then the process sped up a bit. I got the grill back on and made sure that nothing was rubbing or touching where it shouldn't be. All in all, I was happy with how it came out.
I put the bumper back on and everything cleared! It was about 11:30 and my daughter was asleep so I didn't get a chance to test drive it, but I was overall happy with how it all turned out.
This morning I drove it to work. It doesn't seem to be leaking or have any more air in the system. Driving the truck is kinda like driving something with Saginaw steering. There is almost no resistance in the steering wheel when you are turning on the street. I am very excited to see how it does off-road. The downside is this pump is noisy! Reading the reviews, I was prepared for it but it does make me a little nervous. It sounds like a supercharger or timing gears on a SBC. It's not annoying, but it is definitely noticeable. All in all, I think I will be happy with the upgrade and I am so thankful to everyone that helped! I guess we will see how he does this weekend.
