Probably the most on-the-go complete tool kit for Toyota's Nissan, any Japanese autos METRIC ONLY (1 Viewer)
Calgary
look what I found
I found this metric-only toolset
Product No.:09014A​
Product Name:122Pc. 1/4"&3/8"&1/2" Dr. Automotive Tool Set​
SATA 122pcs Metric only
10-piece 6.3MM series hexagon socket set (4, 5, 6, 7, 8, 9, 10, 11, 12, 13MM)
4-piece 6.3MM series long hexagon socket set (8,9,10,12MM)
11-piece 10MM series hexagon socket set (9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19MM)
4-piece 10MM series long hexagon socket (13, 14, 15, 17MM)
8-piece 10MM series hexagon Torx socket set (E8, E10, E11, E12, E14, E16, E18, E20)
2-piece 10MM series spark plug socket (16,21MM)
7-piece 12.5MM series hexagon socket set (20, 21, 22, 24, 27, 30, 32MM)
17-piece 10MM series bit socket set
Torx (T20, T30, T40, T45, T50, T55, T60)
Hexagon (3, 4, 5, 6MM)
2-set Phillips screwdriver (#1, #2); slotted screwdriver (5.5, 6.5MM)
3-piece special quick release ratchet wrench set (6.3MM series 5", 10MM series 8", 12.5MM series 10")
3-piece universal joint set (6.3MM series, 10MM series, 12.5MM series)
2-piece 10MM adapter set (3/8" square hole X 1/4” square head, 3/8" square hole X 1/2" square head)
5-piece wobble socket set (6.3MM series 2", 10MM series 3", 10MM series 6", 12.5MM series 5", 12.5MM series 10")
1-piece 6.3MM series bit handle
1-piece 6.3MM bit adapter (6.3MM bit jack)
18-piece 6.3MM bit set
Slotted (4, 5, 6.5MM); Phillips (#1, #3);
Center hole Torx (T-10, T-15, T-20, T-25, T-27, T-30, T-40);
Hexagon (3, 4, 5, 6MM); Pozi (PZ#1, PZ#2)
11-piece full polish combination wrench set (8,9,10,11,12,13,14,16,17,18,19MM)
9-piece hex key set (1.5, 2, 2.5, 3, 4, 5, 6, 8, 10MM)
2-piece A series Phillips screwdriver with through blade set (slotted 6 X 100MM, Phillips #2 X 100MM)
1-piece T52 cylinder head screw socket
1-piece filter combination wrench 63-102MM
1-piece automotive circuit tester 6 V/12 V/24 V
1-piece combination wrench with long X handle 13MM
So most of the sockets are 10mm drive? That would sure suck for those of us with 3/8" ratchets and extensions. 3/8" and 10mm do not interchange. That's a big difference.
I have confirmed with SATA the ratchets and extensions are 3/8s
This could certainly be a solid option for anyone that doesn't already have a decent stash of tools. I could only find one price in Malaysian Ringitt sp? came out to about $183.
SATA tools are made by apex tool group. So expect similar quality to gearwrench.
3/8" = 9.52 millimeters. Half a millimeter is pretty small.....
with this type of relatively inexpensive kit, I would want to know how much slop there is in the wrenches and sockets. I have seen quite large differences ranging from very tight to awfully sloppy. It starts being important when you have to reef on stuff to get it loose or tight.
  • Like
Reactions: PIP
That's a mile in my world. That's 480 microns.
And in a regular Joe practical sense, no, 3/8 and 10MM do not fit together and do not interchange. If you tried to drive a 10MM female square with a 3/8" male square it would fail at a significantly lower torque than a properly sized connection would.
It would be almost the same scenario as trying to tighten a 6mm SHCS that has a 5mm internal hex using a 3/16 hex key. If you've tried that before you may have found it doesn't work great.
I was just there! I had to buy a 10mm box wrench at an Autozone to fix something the parking lot. The wrench was way oversize, it was difficult not to dtrip the fasteners.
Never been a big fan of kits or those blow-molded plastic boxes that they come in. Kits invariably have tools that I don't want or need. Too much wasted space in those boxes. I use bags and rolls as they don't allow the tools to bang and clang on the trail and they are compact.
I bought a Craftsman kit once as the stepping off point in building a tool bag for chasing desert race vehicles. I knew that quite a few of the included tools wouldn't ever leave the house (all of the 12 pt. sockets for instance), but the kit was on sale for less than what I would pay for just the tools that I wanted.
If you're just starting out and haven't developed curmudgeonly traits like yours truly or don't have a refined feel for what tools you want and need to carry, then a kit might make more sense. But I'd still dump the blow-molded case and work out a bags and tool rolls solution. Amazonian 4x4 Supply has an amazing selection of these.
