look what I found
I found this metric-only toolset
SATA 122pcs Metric only
Product No.:09014A
Product Name:122Pc. 1/4"&3/8"&1/2" Dr. Automotive Tool Set
◆ | 10-piece 6.3MM series hexagon socket set (4, 5, 6, 7, 8, 9, 10, 11, 12, 13MM) | ||||
◆ | 4-piece 6.3MM series long hexagon socket set (8,9,10,12MM) | ||||
◆ | 11-piece 10MM series hexagon socket set (9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19MM) | ||||
◆ | 4-piece 10MM series long hexagon socket (13, 14, 15, 17MM) | ||||
◆ | 8-piece 10MM series hexagon Torx socket set (E8, E10, E11, E12, E14, E16, E18, E20) | ||||
◆ | 2-piece 10MM series spark plug socket (16,21MM) | ||||
◆ | 7-piece 12.5MM series hexagon socket set (20, 21, 22, 24, 27, 30, 32MM) | ||||
◆ | 17-piece 10MM series bit socket set | ||||
Torx (T20, T30, T40, T45, T50, T55, T60) | |||||
Hexagon (3, 4, 5, 6MM) | |||||
◆ | 2-set Phillips screwdriver (#1, #2); slotted screwdriver (5.5, 6.5MM) | ||||
◆ | 3-piece special quick release ratchet wrench set (6.3MM series 5", 10MM series 8", 12.5MM series 10") | ||||
◆ | 3-piece universal joint set (6.3MM series, 10MM series, 12.5MM series) | ||||
◆ | 2-piece 10MM adapter set (3/8" square hole X 1/4” square head, 3/8" square hole X 1/2" square head) | ||||
◆ | 5-piece wobble socket set (6.3MM series 2", 10MM series 3", 10MM series 6", 12.5MM series 5", 12.5MM series 10") | ||||
◆ | 1-piece 6.3MM series bit handle | ||||
◆ | 1-piece 6.3MM bit adapter (6.3MM bit jack) | ||||
◆ | 18-piece 6.3MM bit set | ||||
Slotted (4, 5, 6.5MM); Phillips (#1, #3); | |||||
Center hole Torx (T-10, T-15, T-20, T-25, T-27, T-30, T-40); | |||||
Hexagon (3, 4, 5, 6MM); Pozi (PZ#1, PZ#2) | |||||
◆ | 11-piece full polish combination wrench set (8,9,10,11,12,13,14,16,17,18,19MM) | ||||
◆ | 9-piece hex key set (1.5, 2, 2.5, 3, 4, 5, 6, 8, 10MM) | ||||
◆ | 2-piece A series Phillips screwdriver with through blade set (slotted 6 X 100MM, Phillips #2 X 100MM) | ||||
◆ | 1-piece T52 cylinder head screw socket | ||||
◆ | 1-piece filter combination wrench 63-102MM | ||||
◆ | 1-piece automotive circuit tester 6 V/12 V/24 V | ||||
◆ | 1-piece combination wrench with long X handle 13MM |
