For Sale PRICE DROP 1997 Factory Triple Locked LX 450 (3 Viewers)
Year
1997
  1. LX450
Mileage
261000
Color
rgb(100, 100, 100)
Got a compression test done in June
#1 175
#2 160
#3 160
#4 170
#5 175
#6 170
Also installed New oem plugs, Distributor cap, Rotor, and sparkplug wires, and entire cooling system within the past 6 months.
Up for sale I have an extremely off-road capable 80 series Landcruiser. This is the 2 year only Lexus lx450. It has the more desirable 1fz-fe motor. On the highway it will drive 80 mph stable with zero issues and I trust it on long overland trips. It has the factory front and rear E-lockers and is AWD all the time. Unfortunately, looking at going back to school and need to sell this to afford my masters degree. I would love to see this go to a home where it's put to the use it was built for.
Interior:
VW GLI front seats
Uniden CB (disconnected for now)
Kenwood Media player
Kenwood 4ch and sup amps
Alpine 10in sub in custom quarter panel box
Pioneer components up front
Pioneer speakers in rear
Rear Attic for storage
Wiring distribution setup in rear for Fridge, compressor or similar electronics)
Ram mount on dash
Clock delete with USB port added
Fire extinguisher mount at driver seat base
A pillar flashlight mount
Center console mod with OEM sub delete making more room and adding a cup holder
LED’s replacing most if not all lights
New window regulators
Blue sea fuse panel in dash for Accessories
Under the hood
Dual 100AH northern AGM batteries
Norco Battery tender
Smart isolator
Relay box for Aux electronics
Newer Brake booster
Bosal downpipe
Older Magnaflow exhaust
PHH fixed
EGR Delete
HG done around 220k by previous owner
Suspension
40x12.5.17 Milestar Patagonia on Fuel wheels
Includes spare wheel
Dual steering arms allowing for GM 1ton steering
Front axle moved 1.5in forward
Dobinson 4in HD coils
OME shocks
Slee Forged Radius arms
Slee Stainless brake lines front and rear
ABS delete
LSPV delete
Airbag Delete
Sway bars removed but still have them
Nitro 5.29 gears
Both axles were rebuilt in the last 3-4 years.
Exterior
4x4labs front bumper(early higher built one with modified blinkers to corner blinkers
Smitybilt x20 12k (wireless)
4x4labs rear bumper with single swing out (no attachments)
Ironpig transfer case skid plate
Double cardan front shaft built in 2019
Rear drive shaft rebuilt 2019
Depo headlights
Custom Relay harness for Non US headlights
55w HID high beams
32in vision X light bar on roof
ARB full roof rack
360 Degree lighting with led pods on rack
LED light bar in grill
Custom front grill shaved for light bar and headlights to work
TRE snorkel
Metallic graphite Raptor liner lower
Single stage dark gray top
Vinyl camo over gray
Front and rear wheel wells modified for larger tires
OEM front and rear sway bars
Slee sway-bar spacer parts
OEM Celica steering wheel
OEM transfer case shift boot
Probably more I am forgetting
Also Known as a Landcruiser
Know items that could get fixed:
Cracked windshield
Chips in bedliner from use
Asking: 23,000
how much without the tires and rims? pm me if ya want
Could you post some photos of what was done to modify the front fender wells? Thanks.
Did I just see your rig in Pagosa Springs just a little earlier?
Is it still for sale? If you're still in the area, I would love to look at it!
