Preventative maintenance questions (pay the man or DIY) (1 Viewer)
Hi. Long time lurker + med- to light-competancy wrencher. My question is this: we are giving our 175k mile 2004 LC to our grown daughter. She asked! I want to do so some prev stuff before giving it to her soon. All parts in-garage for the following work. Just running out of time because I am busy at work:
Group #1:
real alternator
repl radiator, thermostat, serpentine belt + tensioner
timing belt kit (belt, water pump, etc)
heater tees
- quoted $2000-ish labor only (Nashville area too, BTW)
Group #2:
front brakes (pads/rotors) and bearings
rear pads only + rear shock swap-
- quoted $750-ish labor only
Group #3:
fluids + lubes (less oil)
- quoted $500
I know #2 is not as straight fwd as the BMWs I have done countless times. I know #3 is DIY-able too. #1 is my main question. Alt and rad seem straight fwd enough, but with low-exp on Toyotas and a limited timeline to get this done...would attempting #1 be worth the savings or not. Again, not a complete auto repair newbie but limited exp on Toyota work. Seems like doing all #1 at once saves lots of duplicitous work since the alt will be much easier if I am taking all the other stuff apart to get to timing belt fix.
Opinions? Completely subjective responses expected and appreciated.
Thanks.
Start with the easiest jobs and work your way up, basically 3, 2, 1 from your list. If you get through #2 you might be feeling ready for #3, or not in which case you'll farm it out. But at least you'll save money on the first two.
#1 and #2 are labor only? you supply the parts?
With limited time I don't think I'd spend it researching and DIY'ing jobs for a truck I'm giving away and therefore never going to work on again.
If I was giving a car to a child I'd be sure to get the brakes done and any other safety related items before handing it over.
Then if I didn't want to pay for the rest, I'd throw the remaining parts in the trunk as a gift. Let your daughter decide when she wants to get them done. It would make for a good lesson in what's involved with owning one of these.
Not just any kid...greatest daughter e-v-e-r. I'd give her one (maybe both!) of my kidneys if she needed that, so what is a bit of prev maintenance! :)
If you didn't want to get into the time & intricacies of a full TB/WP job you could split group 1 up and just DIY the radiator, serp belt + serp tensioner, alternator, heater Tees and refill coolant. No special tools or FIPG required. (what's wrong with the alternator though?)
The radiator doesn't have to come out for a TB/WP job so I don't think you're leaving any shared shop labor discounts on the table here anyways. Worst case you are paying for a couple extra gallons of coolant. I imagine you could get the TB/WP labor for close to or even under $1k if you shop around.
Good suggestion, thx. This might be my plan actually.
Per alt, truck has a parasitic draw...(without Tender) battery craps out after 3-4 days being parked. Found good deal on Denso reman, so replacing that as well so she doesn't have to worry about it.
You probably want to chase down the parasitic draw with a multimeter. I traced my parasitic draw to the Radio fuse. Then further isolated it to the 6 cd changer connection buried under the center console. I unplugged the connection (my cd changer didn't work anyways) and no more draw.
