Pre-03 nav delete how-to (15 Viewers)
I was under the impression that a right hand drive bezel would work for my lx470 so I ordered one from overseas and now that I have it the wiring diagram is completely different. Has anyone had this issue or know a solution. Here is a picture of what my A harness looks like. Completely different than what the chart shows. The other 3 harnesses are different too. Any advice would be greatly appreciated!
yeah it is definitely different, good news and bad news, good news is you have the connector and electricity doesnt care about the color, and you have the connector, but probably not the pins to re-pin it. Bad news is it makes it harder to confirm you are wiring the correct wire to the correct spot, if it were me, id go through and label each one of those with the known color before i did anything, then id go one wire at a time (as recommended in general) and re-wire. OR you could get the correct pins and re-pin but you would end up in the same spot you are now, so id just do what i just said and label those all with the known colors and begin wiring.
but on the other hand, maybe they didnt wire the center console the same? hmm, interesting actually. which center console did u get (3 knobs or digital)
if the center console is wired the same internally, then id also consider removing all pins and just place them in the spot corresponding with their color
I got the one with the 3 knobs. Would there be a way to determine if the center console is wired the same internally? Here is the one I got
2 options i can think of, hook a coupla things up and test if those work , or find a wiring diagram from japanese version and see what each color is and correlate them to your colors
Looking at it again, not even the empty slots line up. On harness A there should be 6 open pins but on mine there are only 3 so I can't really even test it that way. I guess I'll have to look and see if I can find a Japanese diagram.
Here are the wiring diagrams for the 2002. Note the only difference is the navigation into the speaker and the now deleted MFD controls. This is so your navigation can give you turn by turn directions. When you pull the navigation system you will lose your left speaker unless you bypass.
@TXSunDevil - I pulled my navigation unit under the passenger seat a few week ago. Just as you stated, I lost the left front speaker. What do I need to do in order to get the speaker working again? I'll be using the Metra 70-8113 to connect to the JBL amplifier.
I believe I posted a schematic. You just connect the two speaker wires together that were switched by the nav unit under the seat
Thank you. I just found the wiring diagram. Much appreciated!
  • Hulk
