When driving this weekend on a very windy road I noticed that my power steering started to whine a bit and was vibrating a bit. I have been putting off flushing the fluid (148k miles 1996) but when I got home and checked it, found the fluid had gone from slightly brown to obviously overheated and nearly black. I am guessing the back and forth on the steering wheel pushed the fluid over the edge and overheated it. So last night, I decided to flush the fluid using RavenTai method.
The fluid that came out was not red, not brown, but black. I ended up using almost two quarts of Redline D4 ATF in the process of the flush, running it through until the fluid came out bright red. The pump is definetely running a bit smoother now and isn't whining as much. I am going to see how it does and may try the Downey trick if it gets any louder again.
In short, you may want to do this 40 minute 1 job if you haven't. I may have damaged the pump by leaving the old fluid in there so long. You don't have to use synthtic ATF, you can use mineral ATF and do the entire job for less than $5.
