Power steering fluid question (3 Viewers)
Los Angeles, CA
My power steering fluid is a bit low and I want to top it off. I know the manual calls for Dexron III but I don't have that. I do have Toyota ATF WS and also Valvoline Maxlife ATF which is compatible with Dexron 6. Which one would you recommend?
I recommend driving to the auto parts store and buying the right fluid
check out the following threads:
Why is it low? After you figure that out, if it’s just a matter of a couple ounces I would leave it alone rather than adding whatever you have sitting around.
The car has 105K miles on it and it's probably never been replaced. It's a bit low and that's not super odd given the age. I will do a complete flush soon but for now I just want to top it off with what I have. Looks like some people have used the Valvoline with no problems. But still not sure if these two are really different from the Dexron III or is it just all the same....
Napa auto parts has Idemitsu PSF in stock around me. Idk about CA, but that's the stuff they use from the factory as PSF per CCN (all hail his name).
To answer your question Dexron VI is backwards compatible with Dexron III and can be used in this application. You have the right idea by putting a flush on your agenda.
I’ve been using DexVI for about 60k miles without issue.
I know.
The backwards compatibility objective was enough to convince me.
I would not put WS in there though. The fact that toyota would specify DexIII when they have WS in their regular parts system tells me there is a fundamental reason it's not a good idea. Without knowing what that reason is, I can't make an informed decision.
TBH the Idemitsu stuff is probably best but Napa bailed on my market a long time ago.
I know.
I agree. Also, just FYI, Napa does not recommend the Idemitsu Power Steering Fluid for use in my 2013 Land Cruiser:
:meh:
HTH
:meh:
HTH
Probably says that because the owner's manual doesn't explicitly allow it.
Then again the manual calls for DexIII which doesn't seem to be in a 200 from the factory.. Or if it is, they got it without the dye.
I wonder who in Toyota Engineering that CCN got that information from, or if he's just stating assumptions as fact.
Napa do recommend other "Power Steering Fluid" products which make no reference to Dexron III compatibility:
Again ... :meh:
I decided on Mobil 1 Dexron III compatible ATF as my PSF substitute.
Again ... :meh:
Good catch, but I still wouldn't put much weight in it.
Even toyota doesn't know what parts fit their vehicles on occasion.
  • Back
