Power steering fluid question (3 Viewers)
Los Angeles, CA
My power steering fluid is a bit low and I want to top it off. I know the manual calls for Dexron III but I don't have that. I do have Toyota ATF WS and also Valvoline Maxlife ATF which is compatible with Dexron 6. Which one would you recommend?
I recommend driving to the auto parts store and buying the right fluid
check out the following threads:
Why is it low? After you figure that out, if it’s just a matter of a couple ounces I would leave it alone rather than adding whatever you have sitting around.
The car has 105K miles on it and it's probably never been replaced. It's a bit low and that's not super odd given the age. I will do a complete flush soon but for now I just want to top it off with what I have. Looks like some people have used the Valvoline with no problems. But still not sure if these two are really different from the Dexron III or is it just all the same....
Napa auto parts has Idemitsu PSF in stock around me. Idk about CA, but that's the stuff they use from the factory as PSF per CCN (all hail his name).
