I've gathering parts to add a power steering cooler...probably this weekend. Wanted to run the plan by folks who have already done this to make sure I'm not missing anything and see what anyone thinks.
My stock power steering cooler is not rusted at all (which makes it sad that I would have to cut it up) so I'm thinking of utilizing it in my set up.
I'm going to order a heat sink 12" long cooler, with 3/8 fittings on each end. I picked 12" to give me room to work under there with the hoses and connections and also add a temp sending unit. Then cut the stock cooler out, utilizing some of those stock cooler lines to connect to the new cooler. I'm wonder how "flarable" the stock lines will be using a standard 3/8" flare kit. Anyone have any ideas?
As a back up plan, I have a pipe cutter and flare kit on order and could just add all new hard lines like others have done.
I also have plans to add a temperature sender in the line. I don't think I've seen anyone do this and it might be interesting to see what temps the fluid gets too. I already have a trans temp gauge (VDO 150-400 degrees F) and I'm thinking to keep things simply plumb in a sending unit and wire it to my trans gauge with a swtich so I can flip back and forth between trans and power steering temperatures on the same gauge.
By the way, does anyone have any idea what the temperature range is for the power steering fluid?
Finally, will flush with new fluid per the many instructions on here. Thinking of Mobil 1 tranny fluid. Would this work? Anyone have issues? Did some searching and found that some folks seem to be OK while others developed problems, but hard to say if it's the fluid or other issues.
Thanks much for any advise!
