Power steering binding after rebuild
Sydney, Australia
Hi all,
I've just rebuilt the engine on my 1990 HDJ80. This of course required removal of the power steering.
Everything is back and running well except the power steering. I have put new fluid and with the car on stands (under the diff) I added the power steering fluid.
I checked the fluid level, all good, turned the steering from lock to lock multiple times to bleed it and all seemed well.
When I lower the vehicle on to the tyres the steering becomes impossibly heavy.
I turn the wheel to the left lock, Ok. Then I turn towards the right and get 5 deg past centre and the steering binds.
I lean on the steering wheel and eventually get to right lock but it is not driveable.
When I move the vehicle out of the garage to check further the point where if binds changes. Sometimes left side, sometimes right.
I've checked the steering linkages and nothing is contacting.
I did a swivel hub rebuild at the same time and steering pre-load was correct.
This is driving me crazy.
Anyone got ideas, . . . . . please?
I misread the first post, but glad I posted to "bump" the post.
I agree with @60wag - That sounds like a good place to start.
Sounds like the steering gear was never disassembled. I'd separate the drag link from the pitman arm to isolate the problem to either the steering gear or the front axle.
Problem found and it had nothing to do with the steering. The vehicle has factory electric lockers. The front diff was actually showing Unlocked but remained in the locked position. I took the drive motor off, moved the rack to the right and unlocked the diff manually. Steering works correctly now.
Awesome! I am glad you figured it out!!!
