Where is the best place to find power and constant 12v for the cb radio?
TIA
TIA
Another option is to wire your CB with a 12V plug and use the cig lighter for power. This setup works well for me as I don't need the CB in the truck during daily driving duties. I typically have it stored in the map pocket of the drivers door. When I need it, I slip it between the emergency brake and the center console, plug it in and I am ready to go. Just another option.
make sure you tune your setup for SWR before you use the radio or you can damage it.
I recently just installed a accessory fuse block under the passenger seat just for such things. Mine is set up for constant power hot. But you could do something switched if you wanted. Power comes directly from the battery via 6 AWG with a waterproof circuit breaker inline under the hood.
