A not insignificant amount of suspension lift... it used to be 5 inches, it's since sagged a lot!... I'm looking at a new set of TJM XGS Suspension shortly as I don't want the OME stuff from ARB. I'm good mates with the TJM dealer here and he says if I don't get 5 years of solid trail running outta the TJM Stuff, he'll replace whatever breaks free of charge
Bullbar is being replaced with a TJM T-13-something winch bar to mount a 15,000 lb TJM Ox Winch. I can't justify spending the extra 1000 dollars on a Warn as I'll use it once a month at the absolute most. Probably more like once every 3 months.
Adding another two lights on the roof to make 6, even though you can't see any in this photo. There will be two IPF driving lights in the new bullbar to making a total of 10 forward facing lights, of which 4 are converted to HID. (which if you go bush a lot at night, I can't recommend enough).
There's a couple, soon to be 3 of Bond Ultimate batteries with 950 CCA under the bonnet. They're rated at 750, but we tested them at Bond and they came up at 948 CCA. They come with warranties to start tractors (the farm kind) for christs sake!
Snorkel is on the way, will be fitted when the 1uz-fe goes in and mated to my new LPG Mixer. This doubles as making the rig affordable, the exhaust dumps out either side as you can see if you look really closely and this setup will be retained. Once the new 1uz is in, we're expecting around 360hp-390hp @ the flywheel with the exhaust and intake and otherwise stock 1uz and around 425 ft. lb of torque. (I just did conversions from metric, so they might be a little off!).. 275kw and 570 Nm...
There's other things happening to the rig, i'm building a custom drawer box for the back. It came stock with a rollcage as all 73 series in Australia ... so on.
And yes, those are 33x12.5x15 Coopers STT's.... which I love to death. They handle awesome ON road too.
