There's low level knock, and then there's serious engine grenading knock.
Using 87 octane in the LX570 calibrated for "premium unleaded gasoline only" would result in low grade knock, i.e. additional wear and tear.
You won't find any anecdotal examples of grenaded engines to tell you you're doing it wrong.
What will happen is progressive additional wear and tear. The kind that would manifest in lower compression at higher mileage, including more blow-by, oil consumption, and loss of power. Perhaps an earlier headgasket failure at higher mileage.
Those must be cheap compared to money saved on gas right?
You guys suggesting that information in manuals are akin to marketing have no idea how engineering organizations are run. Engineers and tech writers write manuals. If you want to know the inside scoop, there's no better way to receive it. Details are not minced here and are a result of objective validation and testing. Especially in world class engineering organizations such as Toyota/Lexus.
Disclaimer: I am an engineer and a systems developer, but not an automotive engineer.
I always admire TeCKis300's posts and I concur that tech writers and engineers primarily write the manuals. I believe, however, that good engineering - and we know that is the case with Toyota - would mitigate risk of damage to the engine if lower grade fuel were used than exactly that required according to the fuel map to obtain optimum performance. If not, all of the trucks running in third (and first?) world countries burning fuel that was not perfectly in spec would be at risk as well. After all, four points of octane difference between 87 and 91 is only 4% and I just don't have faith that all the gas suppliers are as capable as I'd like them to be and maintaining greater than a 98th percentile quality control rating for octane in the gas they sell me. Worse, I don't necessarily trust that I am getting premium every time I pay for it just because I chose the more expensive option. How do we know that the 91 is really 91 anyway? And what about all of the 87 being put into the LCs on the Asian and African continents? Is it exactly that?
Toyota had better have engineered the engines (whichever type they are) to run a long time on less than optimally produced fuel. I'm gonna opine that timing is modulated when a degree of knock is detected due to poor fuel such that potential damage can be avoided or at least significantly minimized. Obviously, the system's ability to adjust would be limited, but certainly it would accommodate slightly less and slightly more than 85-93 octane.
I do, however, believe that the LX engine's fuel map, whether it is actually different than that of the LC or not, may actually deliver a bit more power on a higher octane fuel. Maybe the LC will as well?
That said, I hereby volunteer to apply all IH8MUD donations received to a deliberate dyno test using my '11 LX to get to the bottom of this matter once and for all! I'll make a couple of runs on 87 octane and then switch to 91 for a couple of days to allow the engine management system to respond and then go back for runs at 91.
If I don't receive enough money for the dyno tests, I will apply what I do get to a set of sliders and post pics for the forum's enjoyment.
Agreed?
