I think we are in complete agreement about using the appropriate grade fuel, to summarize and address the OP... incorrect fuel grade and insufficient octane rating can reduce performance and potentially subject the engine to damage.
In later posts it seemed that others were advocating the use of higher grade/octane fuel to increase performance/mileage on engines designed to operate on lower grade fuels .... that was the intent of the Engine Master posts to show that in a specific objective test (anecdotes are subjective tests) no improvement was noted. I believe that in my 200 I would get no advantage to running premium all the time. That being said .... it is possible that in a situation like you describe that I could see LESS performance degradation by running 91 octane but not truly an increase hp and mileage. I guess it really is semantics but in summation the best I can achieve with 91 is just normal performance in a worse case situation ( and yes that is a good thing)
Copy. For the LC, I would just run what's required - 87. There will be limited advantage to running more octane. That said, in extreme cases, there has shown to be some benefits. Too many variables to say if a stock rig on stock tires, towing a milder load could see the same.
DIY Smartphone Scan Gauge - OBD Fusion
Apologies if this has been answered, but which of the OBD monitors would you recommend if price is not a priority. I’m an iPhone user and like data and relative ease of use. I’m using iPhone with VeePeak OBDCheck BLE Bluetooth scanner ($34) and OBD Fusion App ($10) for iOS, with Toyota codes...
forum.ih8mud.com
