get out, wat lift kit is thatHere is mine, finally.
. Details on the lift?Here is our sponsored FJ with 35.
tail shaft spacers and properly adjusted control arms fix thatLooks like a 6" kit with diff drop brackets in front. It's not kind to prop shaft angles.
Are you using wheel spacers? If so, what thickness?315 KO2s with 2.5-3" lift, stock geometry. Total Chaos uppers with new Icon Delta Joints installed. TC support gussets installed on the spindles. Some closeups after rebuilding my spindles and UCAs over the past couple weekends...
You can see where the tire rubs the UCA on full compression and turn in the first pic. In the second pic, there is about 1/2" gap between the spindle gusset and the sidewall. Then the last pic is with the wheel turned in (shot from behind the wheel towards the bumper) and you can see the tread approaching the UCA.
View attachment 1762045 View attachment 1762046 View attachment 1762047
I have 1" spacers on the front. I could probably run without them, but the tires would be really close to the spindle gussets, like less than 1/4".Are you using wheel spacers? If so, what thickness?
I have a set of FJ80 Land Cruiser Wheels that I plan on installing soon. I've heard they don't clear the front Calipers without spacers.I have 1" spacers on the front. I could probably run without them, but the tires would be really close to the spindle gussets, like less than 1/4".
Do you think 1/4" spacers and longer wheel studs would do the trick?As do I... and yes, you are correct. The casting on the back of the spokes is just about 1/16" too close to the calipers. I have shaved my calipers in the past, but it's a pain.
