- Thread starter
- #21
More
yeah airbags inside the coil springs, but htey are at 5 psi or less in L mode and provide no lift especially in N, I have new AHC springs that ive have for about 6 monthsWhat rear springs do you have?
You also mentioned airbags? Like leveling airbags when towing?
Nah, it’s all in the books. Books + Techstream + experimentation = results (sometimes)@PADDO's knowledge is unreal sometimes![]()
Yes, what I am showing is that it's not just "stiff" its locked out, and when I am driving in H its perfect and I can watch the damping change from 1 to 16 while moving BUT when in N it says (OBDlink) its changing but the rear end is locked out still while saying its going from 1 to 16 just like the front is...hench i have no DCT and the computer thinks everything is goodNah, it’s all in the books. Books + Techstream + experimentation = results (sometimes)![]()
Got it.
- Put the truck on low,
- Turn off truck and reset ahc (remove negative battery terminal and wait around 30 seconds before inserting back. VGRS will light up if equipped but will self calibrate after some driving and dissapear)
- Hook up techstream / other device and switch to N mode and send back the new pressure readings front and rear.
- Check to see if pogo stick is still occuring while driving.
Is your rear height sensor in its stock position?
What’s the ride quality like at N with the system manually locked at damper setting step 1 front and rear? If you’re seeing the rear step changing whilst in motion then that suggests the control side of things should be (could be?) ok. I’d love to know what your actual pressures are, via gauge and not from the pressure sensor, at N. Comparing suspension performance at H (and up to the 19mph limit) should be irrelevant because that extra 1.5+ inches over N really bumps the pressures up to the detriment of dampening. Now if dampening is better at H (with higher pressure) then that suggests your pressures at N are too low. Either too high or too low pressure at N, where it’s supposed to be optimized, is bad for damping quality.Yes, what I am showing is that it's not just "stiff" its locked out, and when I am driving in H its perfect and I can watch the damping change from 1 to 16 while moving BUT when in N it says (OBDlink) its changing but the rear end is locked out still while saying its going from 1 to 16 just like the front is...hench i have no DCT and the computer thinks everything is good
Really puzzling - can't understand what the problem is.In N the front is great but the back is so stiff I am genuinely afraid I will lose control of the vehicle, it stays locked out even when I bypass it in the DLC3 to do the 16 step test but when in H mode it goes through all 16 steps just fine. My obd2 indicated pressure on rear in H is right at 6.8 and in N and L it stays above 7 but is locked out so the actual ride is pretty much impossible to tell....I might be able to rent a pressure gauge from Autozone and see what it says.....
