_____________________________________________________________________________________________________
Repost:
"Piston top:
If" this is a pocket of erosion in top surface of piston and not illusion. The piston would need replacing. As it will very likely fail in time. Replace timing belt,
see if runs okay. Drive as you look for good used engine, may be good idea."
_______________________________________________________________________________________________________
The carbon, pits in cylinder wall and piston top and valves. IMHO: Most conditions in 1 cylinder, developed over time. From issue in that cyclinded.
We now see what looks like interference on piston top. I have warn, that under the right condition, interference can happen. It looks like you "may" have those condition. It "may" be carbon on valve(s), close the gap between piston & valves enough. Or issues with valve gap adjustment, valve spring, etc.
But angle, spacing, positions and number of hits on piston. Doesn't look quite right for valve interference. It's like some metal was bouncing around in the cylinder.
I've seen, where a foreign object. Have fallon in cylinder(s). Which enter either through spark plug port or intake port when intake manifold pulled off.
Most common is sand. Which causes cylinder wall (vertical lines) & ring damage.
I've also seen, 10 mm bolt accidently dropped in.
Also, Spark plug blow out. Pieces of spark plug, can drop in.
Then fix for a blown out spark plug; Time-Sert in-situ drop in metal.
To get better idea of valve condition. The valve needs to be open, so seat can studied with borescope. Valve steam may have been bent. If so, valve(s) will not seal, even if seat okay. So it may run worse than it did.
Short block is trash, piston damaged, valves may also be damage. IMHO, this is not a rebuildable engine.
What are we looking at here?
FWIW:
Exhaust valves are smaller lower/outer side of block.
Intake valve are the larger along top row
