That's what I'm talkin' about...
its right here! sorry for the crappy cell phone pic
The signal that a good pick-up will send out will look exactly like the tooth profile. Some ECU's are particular about the signal shape (want square wave, semi-square wave, or sinusoidal). It would be good to emulate the tooth shape of the OE tone ring if at all possible.
I'm hoping that the shop that epoxied something in place epoxied a threaded bung for a sender rather than the sender directly. Would make replacing the sender a bit of a problem. I can see using epoxy for the bung since welding on thin aluminum castings is a crap-shoot as to if you warp it or not. You really don't know if it will warp until you try it, and if the parts is expensive or hard to find....
Was it you who built a VSS on the end of the input (rear side) of a Split-case? I dimly recall someone epoxying a gear to something to use as a tone ring. Seems like that would be an ideal location. I don't know about the problems in securing the tone ring.
Cool! Just didn't want to see a bunch of work go into something that the ECU would reject.
My split-case is gone, so I've no reference for the design details. From what I could find in pictures on the net it looks like there is a nut on the rear of the input shaft that clamps a bearing & possibly more onto the shaft. Seems like a 'washer' with a tube welded to it's OD could project back and carry a welded/bonded-on tone ring. The tube would need to have an ID large enough for the socket for that nut to fit inside of, and that might kill the idea. Dunno. Something like the attached?
I suspect that it isn't just the sensor that is important, but that the trigger wheel (reluctor) also have teeth of the same shape as the original reluctor. Even better if you can use the original reluctor somehow. I'm thinking that you already know this, but I'm stating it just to be clear.yes... I know that the different GM 5.7 engines with fuel injection don't all use the same VSS. As stated above I think that clearly you have to use a VSS signal that teh PCM expects to see. On my 99 5.7 I run the stock GM flywheel...without issue. At present I use a GM VSS sensor with downy adapter.
Hey Phishin',
I'm not sure I'm following what you did to the flywheel? Did you shave it .4"? I'm having a problem with my clutch slave not engaging/disengaging as nicely as with the 2F/4spd. (I have a Vortec V8, Marks adapter, H55F setup now.)
5.7 "vortec" truck engines are not gen III/IV blocks (they aren't the same block as the 5.7 LS1 even though the displacement is the same). 4.8/5.3/6.0/6.2 "vortec" truck engines are gen III/IV blocks and require a different flywheel or spacer to mate to a transmission designed for a gen I block. They otherwise bolt up the same (except for one inconsequential missing bellhousing bolt in the gen III/IV).
me too. thanks for reiterating what I already said...![]()
