- Thread starter
- #61
good to know, I'll do that then.
I think I've run into an issue. I'm using a stock LS1 flywheel as Jim from Downey said that what I needed to do for this engine. I'm using the stock Vortec pilot bearing as well. When I put the clutch fork in, and have the t/o bearing against the fingers on the pressure plate, the clutch fork is almost hitting the bellhousing. I measured where the clutch contacts the transmission input shaft, and it appears as though its right near the end, instead of centered on the splines like on the 2F. It seems as though the flywheel needs more offset or something to move the whole clutch assembly a little closer to the transmission.
Input?
Input?
