To connect to steel tubing like that there are basically three robust options that I know about, and one far less robust option that negates running the braided hose in the first place (hose clamp).
Can use a Swaglok conversion fitting. The Swagelok fittings will run about $30 each in stainless, but they are a lifetime purchase. Something like this:
SS-600-6-6AN - SS Swagelok Tube Fitting, Union, 3/8 in. Tube OD x 3/8 in. AN Tube Flare
Page 2 of this pdf shows how these compression fittings work. They are nothing like the compression fittings sold at parts stores. These are rated somewhere above 3000 psi working pressure depending on the actual tubing used. (Tube specs pdf)
In case you haven't run across it before, there is a parallel industrial fitting range to the AN series known as "JIC". They are directly interchangeable with AN except that instead of usually being anodized aluminum they are either steel or brass. Neither AN or JIC will work with fittings of any other flare angle. If it is not a 37* flare, it won't work right.
Or you could use a tube nut & sleeve, and then flare the tubing to the necessary 37* flare. Starting on pg. 178 of this pdf:
http://hydraulics.eaton.com/products/pdfs/W-HYOV-MC002-E2_Adapters_and_Hose_Ends_110-367.pdf
The 3rd method is to use a male AN/JIC steel fitting and silver-solder it to the tube. Fittings for this are on the bottom of Pg 179 of the above pdf file.
FWIW I've found Orme Bros. to be far more knowledgeable and have the fittings needed than any of the price whores.
