PHH
Since Simon and I did the PHH job yesterday, I thought I’d add to this FAQ thread with a few observations.
The www.sleeoffroad.com site has a few different methods for replacing the heater hose. We effectively opted for the Rick Bigelow method (aka Landtank). The lower bolt on the heater pipe was all but impossible to get at, so why bother. Thanks for the detailed write-up Rick, well done. :cheers:
After it was all done I realized how helpful it was to do this with 2 guys. As usual having 2 brains is better than one. It really helps to bounce ideas plus one guy might have a knack for pushing the hose on and the other might have a knack for pulling off the old clamp. So I’d recommend doing this with a buddy. Also taking a break helps when your jammed up under your truck.
We also found it useful to have a large selection of tools. Many times we found that we had to try one guys pliers or the other’s pliers to get a clamp off. A set of pliers that’s 0.5” longer just might not fit. We probably had 8 to 10 sets of pliers out by the end
Using dish soap was helpful and I’d suggest putting it on the pipe as well in the location that you will be sliding up the heater hose. We also heated the hose with boiling water before starting, I’m not sure how much that helped as it cooled before a guy could get it fitted onto the pipe. Probably helps though.
We used the constant tension lined clamps and then got into a debate on the easiest orientation. We ended up with the screw head facing down and on the side of the clamp facing the front of the truck (screw assembly at the front not at the rear). At first I thought this was a mistake but after screwing around and finally getting installed on my truck, Simon came up with the idea of using a ¼” racket with a very long extension from underneath while I held the clamp from the wheel-well and guided the mini-socket onto the clamp screw head. Another reason for 2 man job. Worked pretty good.
I would have to say the hardest part looking back was getting the old clamps off. The dremel idea might have worked, not sure if there is enough room. Sliding on the new hose is a little tough as well.
my ranking looking back -> :banana: :banana: to a :banana: :banana: :banana:
I agree with Riley that this is less frustrating with two people. You can tag team or go work on getting ready to flush the other truck when your arm gets tired. My comments are that the following procedure worked:
1. remove the bolt holding the auto tranny dipstick, and the upper accessible bolt holding the other end of the PHH heater pipe to the intake plenum at the top back of block, and remove the rubber heater hose here too. This gave enough movement in the heater pipe. As Riley notes, we could not even find the lower bolt holding pipe in place to loosen it but that extra deflection only matters for step 7 anyway, and Riley managed to get the hoses on twice without it.
2. remove the old clamps off the PHH by whatever combination of pliers, vice grips, side cutters and cursing works for you. The outer oem cotter pin clamp had to be pried and cut off in one case but it was possible to pull the pin in the other with vice grips and then it fell apart. The inner oem pinch clamp slid off the hose eventually if you could manage to keep it pinched long enough using pliers or vice grips. It was harder on my truck because the hose was badly bloated and distorted so we had to cut away some of the hose
3. once the clamps are off, just cut the old PHH off with an exacto knife
4. grease the pipe and block nipple with detergent
5. put the new silicone hose in boiling water to soften it
6. slip the clamps onto the pipe. adjust them first so they are just tight enough to hold a position on the hose. I would put the clamps on the opposite way to Shocker's photo above (e.g., with the bolt mechanism on the left side of the pipe and the bolt head pointing down)
7. use the small amt of deflection between pipe and block nipple available slip hose over the pipe and then slide hose back until hose and pipe end are flush.
8. line up the pipe with the block nipple and push the hose on. Your thumb works good.
9. if necessary, use a pair of vice grips adjusted to just wider than the pipe to evenly push the hose the last part of the way to flush with the end of the block nipple
10. adjust the inner clamp to the position noted above and tighten it with a 1/4" rachet and 8mm socket
11. adjust the outer clamp to the same position and tighten from underneath the truck using an extension bar.
Step 2 was the hardest followed by 7. Step 10 was very hard the first time when we had not preadjusted the clamp to not slip around on the hose.
Total "perfected" job time is under 1 hour.
My PHH has already been done the hard way with the wrong clamps. :whoops: But in my quest to keep my engine compartment as cool as possible (An Arizona thing) I cut the backside of the fender skirts out. Making the PHH and starter access more friendly for service the next time.
Phil
That's pretty funny Phil. I was cutting my hand on the fender skirt edge and the thought of cutting it open crossed my mind as well. Actaully I first thought of it when working on my truck so I suffered in pain. When working on Simon's truck he was lucky I forgot about it. ::)
165K miles and the PHH was leaking, so it was time to change it. I read many of the posts about removing the hard line from the block to install a new hose. After looking at it all and thinking, I choose remove the top bolt from the steel tube and then grab it with a pair of pliers and rip it off the lower mount using the Brute Force Method (BFM)! After tearing it off it's second mount, I was able to remove the PHH from the block by hand using the hard line to pull with.
I installed about 18" of 5/8" quality heater hose from the block to the heater valve, completely eliminating the hard line on the back of the block. The whole process took less then an hour. Now if I ever have to replace that hose again (another 10 years from now?)I won't have to deal with that tube.
landtank said:
What a hack! And you actually seem proud of yourself.
The hack was the bozo that designed that setup, what was Toyota thinking? Exactly what tool did Toyota have in mind to remove the bolt on the back of the motor? I have a good set of tools and could not get anything to fit on that bolt.
18" of heater hose is not a hack it is a proper redesign of a terrible design flaw by Toyota. Many factory cars and trucks including Toyotas use heater hose for heater lines.
That rear bolt doesn't need to be removed to do the job correctly. Toyota has always used metal tubing with stub hoses. The old FJ60 had a vacuum tree which ran across the engine. In fact there are tubes in you coolant system that run to and from the radiator. Do you plan on taking those design flaws out also?
I don't think of something with a high failure rate like this part as being correctly designed. Other lines are not having problems so I will leave them alone. This line is a problem and putting it back to stock is not an acceptable solution to me. I don't know if it's the short hose or an inferior rubber but it's clearly a problem as it's having such a high failure rate. I would normally think steel tubing as being more reliable but in this case it's a problem.
When I built my trail buggy with a rear radiator I used tubing to get from the front engine to the rear radiator and then used 2' long hoses to go from the radiator to the tubes. So clearly I don't have a problem with tubing used for radiator.
I believe this solution will be more reliable and is easer to install than other solutions I have seen. I have not seen anyone else doing this so I posted it here as another solution to this common problem.
I respectfully dis-agree with the "high failure rate" statement. What we have here is a piece of heater hose that doesn't like to live longer than 10 years, not a GM automatic trans that takes a s*** at 56,000 miles...............
The PHH IS the PHH because of the difficulty in performing the repair, not the materials used in assembly.
D-
landtank said:
I'm curious how a longer length of the same type of hose is going to extend the service interval of the part?
I am curious why this hose is the first hose to fail on many 80s?
I, for one, find it interesting that one of the few things we can find to bitch about is a 50mm piece of 16mm water hose that doesn't last 300,000 miles like the rest of the vehicle....:D (well, maybe not the head gasket or the oil galley plug :flipoff2: )
D-
It's true, the difference between Toyota and GM makes it's look like they are built on different planets. If we were talking about a GM truck, I would looking at a motor and trans job not a hose!
Every car and truck has something on the motor that's hard to reach! I love my 80, I just hate the damn stupid PHH!!!!!!!!!!!!!!!!. Now it's gone forever. I am keeping a spare hone in the truck so if I ever need to install one on the trail for someone else, I can do it quickly without going under the truck.
Once you know how to replace the hose and actually do replace it before it fails, it's not that bad.
Now if I'd just stop having the odd nightmare over the HG, I'd be better off.
Yep, I know the HG is in my near future.
I have a huge load of parts to pickup on Thursday, 200 miles away down in LA. I was worried I was going to have to pull the trailer with some other truck. I much prefer my 80 for this trip!
>> I have not seen anyone else doing this [long hose to bypass metal tube] <<
>> so I posted it here as another solution to this common problem. <<
Someone posted this suggestion on the 80sCool list about 3 years ago and at least 1 guy posted that he had done this. I believe they left the metal tube in place and just ran a bypass; securing it out of the way. I carry a 3' section of 5/8" hose in my spares with two hose clamps already on it. The primary purpose is to have a quick fix for the PHH if it fails at a bad time.
-B-
There are plenty of hard/impossible to reach items on other cars that never make it to the forum headlines simply because those vehicles don't make it to 150, 200, or 400k miles and need replacing. Believe me, I've been a shade tree mechanic all my life and there are things on cars that would make you cry trying to find a way to replace. And if I do say so myself, I'm GOOD at challenges like that.
Having said that, I'm one of the few that feels the PHH is not really that tough in the scheme of things. I am not dainty in the hand department and had no trouble replacing mine in about 30 minutes once I had the wheel off. I'll be doing it on my brother in law's 80 either tomorrow evening or Monday. I think what's happened is that we in the 80 community have made much ado about the dinky little thing and everyone's changing them out of sheer paranoia. My bro in law's rig has 280,000 casually maintained miles and he is in town from LA where you'd think the hose would have failed long ago.
So, yeah they're a lot of trouble for a 2.5 inch piece of hose, but simply because it got a catchy name I believe it has had a lot of undeserved other baggage attached to it.
DougM
Because it's the heater hose, I think alot has to do with lack of use in hotter climates. In those climates the heaters are never turned on so the water doesn't circulate and might actually get over heated do to just standing still next to the block for all those years.
Everytime I've had to replace a hose on a vehicle the failure was always at a bend. The rushing water would wear away at the inside of the hose at the turn. Toyota has eliminated this problem by making the turns in the line out of metal. Not to mention it's at these bends that a kink will happen when a hose gets hot and a little softer.
The biggest PITA is draining the coolant and removing the front tire. I don't see where your improvement eliminates this.
I'm with ID,
I can't remember more than 3 people that this has actually happened to. With that I don't see the point of ripping Toyota a new one over it, or replacing the steel line with a rubber hose. But if that's your cake...eat it. I think we're all just a bunch of paranoyed overprepared fools carrying around more odd spare parts than my local dealer. And that's the way I like it. :flipoff2:
Maybe a poll for PHH failure is in order.
