When I was running the small catch can I consistently saw that city driving filled it faster than highway. There shouldn't be a change with the big catch can I'm now running but it is less obvious because I don't have to check it every fill up (so far I've got over 1,000 miles and it hasn't even reached the sight tube yet).
Hey Spooky, Why dont you rig up a drain back system. Instead of a 1/4 NPT plug put another barb and gravity feed it back to the oil pan. Option #1 get a FJ 60 side cover and have it drain into the (FJ60) PCV opening or Option #2 weld a mall bung onto the side of the oil pan and put a barb on there.
Dynosoar![]()
Are you seeing improved mileage as well?
Joel, do you have any pics/info on your setup? I'm curious to see what you're using.
I will try and get some pics tonight. I need to take some pics of my new fan shroud and SPAL fans (all ready to drop in, just need to replace all the hoses and re-install everything).
Here is a link to a polished version of the catch can that I'm running. Why this one? Because I could get it in black. I hate bling under the hood. I almost painted my Ron Davis radiator black while it was out
Riss Racing Oil Catch Can (Polished) Riss Racing
Ohhh, this is interesting. I haven't seen these ones out there before. What material is the sight tube made out of? How do you break it down to drain it? Is there any internal baffling or anything like that to help the oil and sludge separate from the air?
There is a thumb screw with an oil ring at the bottom for draining. It is filled with steel wool. The only downside is that the interior is not accessible to clean/replace the steel wool. The sight tube is plastic of some kind. You can get sights like this at McMaster/Carr if you want to fab your own catch can.
Hey Spook, any extended results?
