Passenger vs Driver Side Wiring Harness Equipment (Left Door Open in Rain)
Illinois and Alaska
Does anyone have an easy reference/guide on what the respective door sill wiring harness mains connect to/control?
Brought home baby number 4 last night and I left rear passenger side door wide open and it rained all night. Pulled door sill covers and it’s moist/not wet. Parent wiring harness connector in front passenger kick plate is dry. Did not see any other connectors in that area aside from sill lighting. No odd behavior - yet…..
This might help. You can at least see what fuses are on each side with the referenced spreadsheet. Wiring diagrams will tell you this too.
If it didn't get a chance to corrode you are probably in the clear. Just lift the carpet and make sure everything under there ends up dry, you should be good to go.
