$10 + shipping depending on area code.....We would all like to know of your source.
Power Steering Res Cap 93-97 [44305-35010-U] - $10.00 : CruiserParts.net, Toyota Landcruiser Parts
This is an ad for a used cap which would be an upgrade if you didnt have one at all.$10 + shipping depending on area code.....
This is an ad for a used cap which would be an upgrade if you didnt have one at all.![]()
Good luck returning it to Cruiserparts.......I might as well not have one, I’ve lost 3 quarts of power steering fluid over the past 2 months I might as well say I don’t have one...
I actually cancelled my order because I don't want to mess around with used parts. Knowing my luck I'd be right back in the same boat leaking power steering fluid everywhere. With no warranty, I'll buy a new one for $6 more.Good luck returning it to Cruiserparts.......
See above....I actually cancelled my order because I don't want to mess around with used parts. Knowing my luck I'd be right back in the same boat leaking power steering fluid everywhere. With no warranty, I'll buy a new one for $6 more.
Thanks bud!See above....
Thanks folks. Just ran it enough to get everything up to temp and then parked it and left the engine running. Turned the wheel hard left reaching arm thru the window and watched the reservoir to see if I could see any spray/leak around the cap. Nothing. Little change in rpm it sounded like but no abnormal noise from the pump or leak at the cap.
Once I get the new cap on I'll clean everything up top and down below then run it lock to lock and see if I can find any leaks anywhere.
I have a new OEM cap if any one wants it. Got it whole sale or $20. $15 shipped, I want to pay good karma forward.
