For Sale Parting out BJ60 83
Tacoma, Washington
:UPDATE OF PARTS LEFT:
I have the rear axle complete, w/brakes, springs thirds ect. 150$
4 aluminum rims 150$
manual steering box 50$
most gauges no tach though
gasser tach
doors
rear driveline
all glass except the rear hatch glass 50$ a window
and random interior stuff
1983 no engine
no tranny
no rear hatch glass
no front axle, housing or third.
no front driveling
Local pickup only for the bigger stuff.
253.359.0349
Looking for a starter for my bj60. Do you still have it?
Also, what is the shape of the wheel wells ? quarter panel
no starter sorry, and the wheel wells are in bad shape again sorry.
The brake line junction that sits on the frame rail? It's the piece the brake lines that come from the firewall go into.... Also, and ebrake handle assembly? And, lastly, a drivers door exterior handle?
No ebrake ill check on that line after work should have that and the handle.
Cool. Thanks a ton. I now just need a handle, found the brake part.
I got the driver side handle and I ebrake assembly. The ebrake handle however has been chewed on by a dog.
tail lights are cracked, license plate assembly gone, and I forgot I used the tachometer in my conversion.
Run a google search for hall effect tachometer, there are a few out there some for under 100$ they are usually switchable from 4-5-6-8 cylinder engines I believe, also you can research what other 4 cylinder diesels use em and maybe pull something from the Junk yard for cheap. Also run a search here for 3788 part number at summit racing. I think i read people are using that one. But its spendy, other then that keep looking up in Canada or across the boarder from you.
