- Thread starter
- #21
Took the transfer case back apart.
Pressed apart the differential shaft and cleaned the needle bearings, they had alot of grease, Lubed with gear oil and reassembled.
It felt really good with the front housing only and the preload plate on the differential bearing torqued to spec. (Had to manually lock center diff to be able to turn with front shaft)
Put the rear housing on and it all went to s***. So maybe the idler shaft is my hang up. I'll be stripping that down tomorrow, cleaning bearings of grease and checking that preload.
At least I can rule that out. If the preload is good and the grease is gone then it has to be a clearance issue I'm missing when I torque the rear housing on.
