Alright here I am with issues.
97 80 series
Quick back story of how I got in this situation.
Questions:
97 80 series
- Rebuilding a junkyard transfer case that was from a rollover. Super clean inside.
- Followed all of @OTRAMM helpful videos but added a part time spool
- While putting the case back together, after installed the preload plate on the differential bearing and torquing to 28 ft lbs. It was very hard to turn by using the rear output shaft.
- manually shifted the case into low and almost impossible to turn.
- Manually locked cdl by pushing the rod towards the rear of the case and same thing by using the front output
- took everything apart and cleaned the FIPG off the case for hours
- Confirmed again that the low gear was not contacting anything in the case where I clearanced by setting the gear set in the case on the bench and spinning
- back together, same issue.
- Tried removing the shims on the differential output to make sure I didn't have too much preload
- manually locked the cdl again with the rear housing off and the shims out while turning the front output, it turns but when i shift the case to low it locks up
- confirmed all of the clutch collars are going the correct way with the Bevel
Questions:
- Can the CDL move too far and casue something to bind when manually operating it (no motor installed, no switches, no ball bearing or spring)
- People that have done this same setup have you any of these issues?
- part time people have you had to change the preload on the differential spool bearing?
