Part identification needed (1 Viewer)
I’ve got what appears to be 2 mounting brackets from a 4-speed bell housing. Need confirmation on that and which one goes to the driver side.
Also have this tube from a 8/71 F motor. Possible “oil pipe cooler”….SOR 055-07A? Does not match up with any of the holes on the side plate cover.
Thanks. Again, which one goes to the driver side. The pipe does not match any bolt patterns on the side plate cover.
What @mattressking said is true. I had to remove mine as it had a bunch of pinholes. Just ran a soft line down to the OC. If you don’t have a need for it, I could use it.
