SOLD SOLD SOLD
This is a set of Paki/Eshan factory soft top style bows. They are in excellent shape, in gray primer. I bought them a few years ago and they have been stored inside ever since. I took them out today to set up for the pictures (Note: they are only had tightened so they whole set-up looks a little asymmetrical in spots... this is only because of the loose assembly). As you can see these are cut an sleeved for easy shipping and storage. Once assembled they could easy be tack welded if you wanted a more permanent set-up. Included are the 2 pieces that go over the side doors AND the windshield top channel to hold the front edge of the soft top.
Also up for sale are the pieces that frame out for a set of soft ambulance doors. (no, I don't have a set of those doors.... I never did, unfortunately). They are assembled to the larger frame in the pictures - again: only hand tightened into place.
Prices are as follows:
Everything pictured and described above: $1200
Frame complete, minus the pieces for the soft ambulance doors:$1050 sold for $975
The pieces that comprise the soft ambi door frame: $250
All are PLUS SHIPPING from NY 11731 or pick up on Long Island or at CMCC in July. FedEx ground is probably your best bet. Being that they are cut/sleeved they will fit in a pretty compact box.
I can also supply a new repro set of the 4 brackets to hold the rear bows to the inside of the tub for $95 shipped in the USA (like those pictured only brand new)
Mark
Mark
