Oxygen sensors for 93-94 FZJ80's... cant find 24044 ntk (4 Viewers)
That is the link of you just click on the picture. 4 in stock.
thay are gone
Heres the Amazon link. Mud seems to default to substituting the pic instead of the actual link, the link is missing the first "h" to prevent the mud image.
ttps://smile.amazon.com/gp/product/B001PNG884/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
It shows 4 in stock currently, for USA at least.
24044 are nowhere to be found.
Buy 2x of 2344520 and be done with it. Inside the DENSO box are NTK OEM Toyota part# 89465-60051. These will be long tails and will work on both sides. Trust me.
So your saying buy the Denso, which are out stock everywhere.
How about the Bosch for $50 or 60 each?
They did not want Bosch because they believe NTK are better and will last longer. Another reason is because someone said they were not good. Reminds of people avoiding WIX because someone posted they messed up their engine. Not based on any real testing or analysis. Plus it’s fun to search and check 20 sites for them and get input from others that they are in stock when they are actually not in stock.
Idk, the Bosch are in stock at Rock auto direct plug and play. Half the price of Denso or NTK. I mean Bosch invented the O2 sensors and the major supplier of O2 sensors for OEM. I even ran the Bosch for 10 years and not a single issue. If that is not good enough then I don’t know what is.
It’s like the article I read the other day of shoppers digging through trash bags at the Gap to buy $100+ Yeezy clothes. Once people make up their mind no stopping them no matter how expensive or difficult it is.
Jeez, I'm glad I went through my o2 sensor issues pre-covid.
if any of you '93-'94 folks are willing to de-pin and re-pin connectors, the choices on Rockauto open up a bit if you search '95 model year.
@Landseer refresh your browser i just contact amazon this item is no more
89465-69115 is the current part number for the right-hand-side 93-94 sensor. The left-hand side was 89465-69125. That number is discontinued. I do not recall which one had the longer wire lead. If it's the right side (outboard side) then it should work in both positions.
@akrover
89465-69115 should have the long tail as mentioned above by @cruiserdan. I believe @12bit also recently mentioned he just bought some from a dealer.
Unless you already called your local dealer and was told not in stock.
I recently received 2x 89465-69115 from Serra Toyota in AL for $108 each
In the end, I ordered 2x 89465-69115 from Toyota USA its OEM and good price 110$ ea. plus
Just checked both Amazon links previously posted. The Denso link shows as unavailable but the NTK/NGK link shows 4 available.
***Update*** Changed the shipping location to Israel and it shows not available.
Amazon product ASIN B001PNG884
Yes you are correct when I changed to my USA address there they were. 4 NGK24080 left.
but in the end, I ordered 2x 89465-69115 from Toyota USA it's OEM and a much lower price of110$ ea. @12bit ordered the same and installed them with no problem although they are short wires like the NGK 24080.
@cruiserdan confirmed that 89465-69115 is correct for 1994.
Thank you all for the help.
Guessing it’s not an exact fit so some sites are stating they won’t fit a 94,
It is the correct current part number for the right side 1993-94 sensor. The only difference between the right and left sensors is the length of the harness. I do not recall which one had the longer harness. If it is the right side it would be easy to use it on the left. If the left side is longer, the harness may not be long enough to reach when fitted to the left side.
I believe the right has the longer harness.
In that case it should work on both sides.
I have two discontinued NOS sets (89465-60110) in storage. I'll have to dig them out and look at the harnesses. The set part number has both sensors, two gaskets and four nuts.
Yes, I have read that ntk was oem for 93/94 as well. Then they switched to denso for ‘95. The only thing confusing me with the ntk is I have read that the 24080 is the one with the short cable, and it was the 24044 that had the long cable (and could thus be used for both banks). Can anyone confirm this? I’d love to buy the 24080’s you posted from AZ if they will work for both sides with no modification.
Just took a look at mine as I just replaced my cats yesterday...as far as the 24080's with the shorter cable...it looks like there is plenty of slack in the harness for the inboard side to reach the pigtail without having to extend anything. The only ever so slight negative is that it won't clip on the little holder inside of the frame, but there are plenty of places to tie it to so it doesn't flop around. I bought mine assuming there was an issue, but it turned out to be water in the plug from driving through a torrential rain...air blasted it out, put in dielectric grease, wrapped it up, re-set the code...no more issues. I'll keep my 24080's in the box until they NEED to be replaced, but I truly do not anticipate any issues with the shorter pigtail length.
Circling back on this, 89465-69115 appears to be the correct part number for the right side (OBDI 93-94) but it is unclear if this is the longer pigtail, in which case it would work on either side, or the shorter. Can anyone confirm that using two part no. 89465-69115 would work with no further modification for this application? It seems that this would be the easiest/best solution if so??
  • Like
Reactions: 405
c​
I suggest trying to find these denso parts, they will work for both sides on a 93 and are long enough for either side. I have confirmed his, as they are on my truck.
To directly answer your question, 89465-69115 will indeed work for both sides. I confirmed fitment with a mechanic friend of mine that installed two of them a couple months ago. We had an in-depth conversation about it before he tried it. His report back was done and gone from his shop. No come-backs.
