That is correct. I spoke with Tech Support this morning and they confirmed. I called the NGK phone # and was asking about NTK part.I was under the impression that NTK was the sensor division of NGK.
Did you have any issues with the white tab that separates the pins? It is slightly different than the OEM that I pulled off the LC.You are good, NTK (made in Japan) is the proper sensor for the 93/94. When I ordered mine Amazon only had one in stock so I bought another one from Partshawk. Both were the same when they arrived.
I installed these about a year ago and they've worked perfectly since. I deleted my PAIR system and installed the new 02 sensors in it's place. The wet stuff on the exahust is Kroil overspray.
- Diesel/LS swap?I want to add that I purchased Bosch in 2020, and they failed me about 2 months ago. I probably racked 20k miles on the land cruiser during this time, so..... Im not trying to add to the Bosch hate, but I am definitely staying away.
What is the current consensus then?
-Denso 234-4520 for both is preffered?
-Toyota 89465-69115 Will work for both, but none are sure if the pigtails are long enough?
-NTK 24080 works for both if you add your oem retention clip?
-Bosch sucks?
Works for both positions. It has the longer harness.-Toyota 89465-69115 Will work for both, but none are sure if the pigtails are long enough?
89465-69115. Any Toyota dealer. You will need 2 of themHey guys i am from canada, ontario for my LC 80 1994, got some issues with the o2 sensor so changed it with the walker brand and thats not working properly , can you guys help me to find where i can buy the best quality one for the 1994
What issues are you having? I have walker brand in my 93 80 located in the PAIR location on the manifold and they've been functioning perfectly fine.Hey guys i am from canada, ontario for my LC 80 1994, got some issues with the o2 sensor so changed it with the walker brand and thats not working properly , can you guys help me to find where i can buy the best quality one for the 1994
