What a great looking product! I had AHC on my LC but no lights on the running boards. Do you know if the power/connector for the lights is present on all AHC equipped LC's or just ones with the optional lighted running boards? Guess I'll have to crawl under the truck and investigate after work
So based on option 1 were you able to get them to light up independent of the other lights with a switch?
I know you're busy, but do you think you can snap a couple of pics of how and where you ran the switch?That's a good question that I do not know the answer to in fortunately. On the LX, the wiring comes out of the body directly underneath the floor where you would rest your left foot while driving (hopefully that makes sense). If yours doesn't have the connector, I would also be interested in knowing if there is an appropriate 1" diameter round hole in that location covered with a rubber seal. If so, wiring these up as rock lights in the LC would be pretty simple.
Yup! It worked out really well. If you ground just one side, while the car is on and the doors are closed, both lights come on and nothing else (door open indicator, or dome light) come on.
As an added bonus, even if you leave the switch on when you get out of the vehicle, the lights will cut off on their own after locking it up. So essentially there is no chance you could accidentally leave them on and kill the battery unless you leave the vehicle unlocked.
The only vehicle I've been able to test that on is mine though, which is an 06. I'm hoping, but not 100% certain the wiring is the exact same on the later model LX's
Would you be able to do a comparison of the 6 led lights next to the 10? Pic or even a vid like your other one? Maybe install a 6 light one on the other side of your rig and do a walk around vid?
Sorry if someone already asked this. But can i keep my LX factory steps and install these to be switchable inside and/or in addition to the factory setup? ( I know i would have to solder/splice wires accordingly) I plan on doing sliders down the road but till then....
If it's possible then i'm in for a set of them
Twenty minutes to install from opening the package to discarding the trash. Simple and easy and the lights look great.
Two thumbs up, would repeat.
Hey Rami, I installed the lights on Friday and boy am I impressed!! Super easy to install and bright AF!! I love them, thanks!! Also, I took off the running boards and my wife hasn't noticed yet, haha!
Next up WKOR sliders...
