Ok, I managed to remove the old crusted PHH and put on a new one. It took my several hours, but I managed to keep all my fingers. I used the gates silicon hose, and the fancy constant tension clamps discussed in the FAQ.
When I finally got the new hose on, I got a little carried away tightening the clamp. I think I needed a caffinated beverage. I pretty much tightended it as far as I could with my little 8mm gear wrench. I then decided that it was probably a mistake and loosened it up a bit. One of those was probably a bad decision. Maybe they both were.
What do you guys think? How tight should those things be? Can you ruin a hose by overtighening?
I would hate to have to do that again, but I would rather do it again now while it is still apart and empty.
Jared
Jared
