overheating
in my little world
ok i think i was wrong... drove around today and the fj got hot... i guess i need a better fan.. i guess you guys like the taurus fan . is that the one that pulles 4500 cfm two speed. the black magic i have is rated at 3000 cfm. is there any certian year i need or should look for. also what is a sho fan
tarus sho was a hi po taurus .your fan with shroud needs to cover 70% of the rad.if your running a stock 4 core keep in mind not all electric fans will move as much air through a 4 core .most new rads are 2 core with wider fins .make sure the area around the rad is sealed so you pull as much air as possible through the radiator .good luck
Ford SHO = Super Hi Output
They also liked SVO for the mustang which was Special Vehicle Operations
Not that it has anything to do with anything here....LOL
