Where are you on this? MIke
I have not measured the vent temps
Get a thermometer, stick it in the vents, and read the temp. Turn your AC on full blast and idle for a while and see what the temps do. Then drive around, and see what the temps do. The report back.
Until you get us more data, we can't help you.
I'll get exact vent temps after I can purchase a thermometer unit, until then I'm certain my estimates are largely accurate.
So... did you or did you not check the cable that goes to the heater valve in the engine compartment on the firewall just to the PS of the EGR?
my A/C loves to kick off while I'm driving. I have yet to do the fan clutch fluid mod and the pusher fan mod, but those are coming.
IMHO your truck is probably overheating. The AC has a cutoff when engine temps climb.
Grench, you bet I did multiple times and replaced it too, that's why I'm curious if I should attempt blocking off the heater core altogether. The engine-side heater/coolant valve response ~linearly with the heat control slide as does the inside air valves behind the stereo (...or I believe it does)...I posted a video of that.
