Truck has 196,00 miles, serviced well thru 100M, and mostly kept current since. 6000 miles ago had transmission pan dropped, fluid drained, screen cleaned, fresh toyota fluid added(mechanic does not recall which toyota fluid).
Truck ran great, shifted smoothly, no problem.
Recently noticed reverse has become very abrupt when shifting from park to reverse. Not a really big deal at cold start since engine is on high idle. But the problem is now the same when engine warm. Recently, when backing the boat into the lake, and shifting to Low(not low range) for the pull out, nothing moved, acted as if in Neutral. Shifted to park, shut engine down restarted shifted to Low, and continued with no further problem. Now when backing (backing only, so far) the transmission will shift out of gear. Recycling shift lever seems to settle the problem immediately(so far).
I have noticed the gear position indicator lights on the panel do not illuminate except when in 2 position with stick.
Any Ideas?
1. Neutral Saftety Switch corrosion?
2. Wrong fluid at change...new WS Spec, too viscous?
3. New fluid cleaned some old wear debris and deposited it in a valve or screen?
4. Internal issues needing a real service expert?
Any Ideas?
