- Year
- 1993
- Vehicle Model
- 80 Series
- Mileage
- 93259
- Color
- Blue
1993 Toyota Land Cruiser in Blue Slate Metallic over gray leather upholstery. Mostly stock. Only 93k miles on the body. Been in California it's whole life so it's rust free. A/C and heat works great. The A/C is R-12 refrigerant. All lights and power windows, seats, mirrors, sunroof, and power antenna works. Interior and exterior are in excellent shape. Some wear on the driver seat and shift handle. Some minor blemishes on the rear passenger seat. Some minor nicks and scratches on the body, mostly on the fender flares and drivers door. No third row. It was missing the third row seats when I bought it. Asking $32,000.
I acquired this truck in Nov 2021 with a blown head gasket. I had an independent Toyota/Lexus shop in Chico, CA (chicocarcare.com) pull the motor and rebuilt it. Slowly breaking in the motor. Have a little over 400 miles on the rebuild.
Rebuild include:
Cylinder head cleaned and pressure test, re-surfaced, grind and adjust valves, replaced four valves, regrind both camshafts
Bore and hone engine block
New connecting rod bearings
New pistons and rings
Polish crank
New timing chain, cam and crank gears, and chain guides
New head bolts
Complete engine gasket set
New Aisin water pump
New radiator, all hoses, thermostat, cap, and both v-belts
New fuel filter and temperature sending unit
Items that I replaced myself:
New fuel pump, fuel pump screen, fuel pump bracket, and fuel gauge sending unit
New battery in Nov 2021
New driver side power seat gear
Rebuild include:
Polish crank
New head bolts
