Original Key!!! (1 Viewer)
I have a strange key issue where I have one key that that will open all doors including the glove box and another code-cut key that works on all doors and can only lock the glove box but not unlock it. The profiles look exactly the same. I'd like to know which ridges of the key are used by the glove box cylinder.
sounds like you have valet key. gotta keep those pesky valets out of the "good stuff".
That's what I was thinking but I can't see any difference in the profiles of the keys. The new key was cut based off the code a dealer pulled for me. I'm wondering if the parts monkey at whatever local dealer I went to didn't know there were separate valet keys and gave me that code instead of the master. I was kind of thrown about the "can lock but no unlock" deal but I can see that as useful feature.
Can anyone out there who still has their valet key see if it'll lock the glove box and not unlock it?
Thanks for the quick shipping Matt. Here is a full set for you. Feel free to snag it.
I suppose that is certainly possible, wish I knew for sure. Key works everywhere without any real issue in all locks but the hatch and glovebox. I initially thought it was just the spare/valet key and the spare I have was based on that. But looking at the first couple posts it sounds like maybe only the original master came with the rubber/molded plastic shell and the spares were metal(?).
Looking at the key it seems to be an original based on guidance earlier in this thread:
Thats a MASTER key without any question
that being said , it WORN out past its service life
PM me your factory key code
i CAN cut you as many OEM SSY Factory Master Keys as you like
your Locks and Me will thank you .............
Had the car at the dealer last week and I asked the dealership if they'd give me the codes, even if I buttered it up and bought a new key from them....no luck, wouldn't give me the key codes. I did order a new key from them for $7 just to see if it would help out with the lock situation.
I'll be pulling some of the door panels off in the next month or two though, when I do I'll check the codes and order one of yours for sure.
its been my experience that TOYOTA has began DUMPING all 80 series . in fact ALL 1990-199 Toyota's vehicle key codes from there TIS network data base as of JUNE 1st 2021
its sadd............. :confused:
Successfully Reproduced 90999-00164 ................:cool:
This is legit. Got mine in the mail today. Finally a solution to my 3 year long search. Thanks a ton, Matt
Stashed my two original master keys and only using the metal vintagey key I got from toyotaMatt. Very pleased. Thank you!
I am using my reproduction key for everyday, saving my one original. Thanks ToyotaMatt.
Example of a older Cold Climate spec land cruiser key
HECK NO !
TECH VIDEO 80 Series COLD Climate Arctic Spec . getting code cut live in front of your TEq EYES !
